Janci's avatar
Janci
xs712t vs xs712t-v2
Hi.
I run XS712t and i want to buy another one for my video editing facility. I see on Netgear site there is now an updated version of xs712 so i would like to know what are the differences/advantages over previous version.
Thank you!
  • Janci,
    I just want to follow-up on this.  Let us know if have further inquiries.
    Otherwise, if ever your concern has been addressed or  resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Cheers,
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Janci,
    Welcome to the community! :)
    About the differences between the XS712T and the XS712Tv2 switches, kindly refer to the table below:
    DaneA
    • DaneA's avatar
      DaneA
      Janci,
      Cheers,
      DaneA
ProSupport for Business
