Varatex
Aug 03, 2019Aspirant
URGENT/11 and Netgear Switches
Hey everybody, Does anyone know if Netgear uses VxWorks on their switches? A quick Google search makes it sound like they've at least used it in the past for some of their equipment. I was hopi...
- Aug 13, 2019
NETGEAR constantly monitors for both known and unknown threats. Being pro-active rather than re-active to emerging security issues is fundamental for product support at NETGEAR.
Kindly check the link below for upcoming updates:
NETGEAR Product Security Advisory
DaneA
NETGEAR Community Team
DaneA
Aug 05, 2019NETGEAR Employee Retired
Welcome to the community! :)
Can you provide a specific NETGEAR switch model/series that you are referring to then I will inquire it to the higher tier of NETGEAR Support. I'll post here once I got a feedback.
I was hoping to understand if this was standard or not and if VxWorks is implemented, could a Netgear rep tell us when we will expect to see patches for the Urgent/11 volnerabilities that were disclosed just a few days ago?
Were you able to check if your NETGEAR device/s are affected by the Urgent/11 vulnerability? If yes, what test/s did you perform that shows that the NETGEAR device/s you have are affected by the Urgent/11 vulnerability?
DaneA
- VaratexAug 05, 2019Aspirant
Hi DaneA! Glad to be here
I put the models we have in the original post, see below:
Model: FS728TPv1|28-Port 10/100 Fast Ethernet PoE Smart Managed Pro Switch with 24 PoE Ports, GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports, JGS524E|ProSafe Plus 24 ports gigabit switch, JGS524Ev2|ProSafe Plus 24 ports gigabits switc, GS324
I haven't been able to test since I'm not too sure how. I was going to assume they are affected if they use VxWorks but I was hoping to get some sort of confirmation from Netgear.
Thanks for your help!
