AssetBurned
May 18, 2019Tutor
Using SFP+ modules in switches that are only SFP capable?
Hi,
So what happens if I pop in an SFP+ module into a switch that can only handle SFP?
From what I read up so far is that SFP+ modules generally should also work in SFP ports, but does so...
- May 20, 2019
The counterpart was always a 10GBase-T resp, 1000MBase-T switch port.
schumaku
May 18, 2019Guru - Experienced User
Tell us exactly what configuration ideas you have in mind.
Be aware the fiber links _never_ use any auto negotiation.
A Multi-gig capable 10GBase-T SFP+ would run at 10 Gbit/s on a 10 G SFP+ slot, at 5 Gbit/s in a 5 Gbit/s slot, ...
AssetBurned
May 18, 2019Tutor
It is more a general question than an practical usecase that I plan to implement.
So from my understanding it is comparable to connecting an 1000Base-T Ethernet adapter to an old USB 2.0 port. The adapter and the connection will still be a gigabit connection, but the bottleneck is the USB2.0 connection. The device that has the USB port would only get the max throuput of whatever USB would give it.
So if I have a connection with SFP+ module for 10G fiber in an SFP slot on one side of the cable. The connection would be still OK, but since that side only supports slower speeds the whole throughput would be limited to 5G as this is the max for the SFP port?
Regarding the autonegotiation.
Well there seems to be modules that can do different rates (maybe selectable by the switch firmware). https://www.intel.com/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf also listed as dual rate at http://www.intel.com/support/network/adapter/pro100/sb/CS-030612.htm within "What are the SFP+ and SFP module requirements for the Intel® Ethernet Converged Network Adapter X520 Series?"
And than there are also those cables that support Cat 6 Ethernet cables that can do it, but those wouldn't be optical.
- schumakuMay 19, 2019Guru - Experienced User
Afraid, I don't think an SFP+ module is supposed to be operational in an SFP slot in general. From some tests with "no-name" but Multi-Gig capable 10GBase-T SFP+ modules, we find that
- SFP+ module plugged to an SFP port (tried several Netgear Smart Managed Plus or Smart Managed Pro models) will be powered,
-- a link to a 10G switch will come up at 10G, but the SFP "interface" on the switch will stay down, no LED activity.
-- a link to a 1G switch will come up at 1G, but the SFP "interface" on the switch will stay down, no LED activity.
- SFP+ module plugged to an SFP+ 10G capable switch
-- a link to a 10G switch will come up at 10G, SFP+ "interface" on the switch comes up, LED on, connectivity OK-- a link to a Multi-Gig switch (tried 2.5G port, 5G port) will come up at the link rate of the per, SFP+ "interface" on the switch comes up (says 10G), LED on, connectivity not OK.
-- a link to a GbE switch will come up at the link rate of the per, SFP+ "interface" on the switch comes up (says 10G), LED on, connectivity not OK.
The point on the Intel document is this: "• Supports rate selectable 1.25 Gb/s or 9.95 to 10.3 Gb/s bit rates" for the fiber SFP+ modules mentioned. There are ways to control/set the speed - there is however no auto speed negotiation on the SFP interface level. For the majority of switch SFP/SFP+ deployments, we need the standard "fastest" rate - being as an interconnection, or to connect some servers.- schumakuMay 19, 2019Guru - Experienced User
To add some confusion:
- SFP+ module plugged to an SFP+ 10G capable switch (MS510TX)
-- a link to a 10G switch will come up at 10G, SFP+ "interface" on the switch comes up, LED on, connectivity OK (as expected)-- a link to a GbE switch will come up at the link rate of the per, SFP+ "interface" on the switch comes up (says 10G), LED on, connectivity OK.
- AssetBurnedMay 19, 2019Tutor
On the GbE side, was that an 10g or 1g module in an SFP port?
