AssetBurned
May 18, 2019Tutor
Using SFP+ modules in switches that are only SFP capable?
Hi,
So what happens if I pop in an SFP+ module into a switch that can only handle SFP?
From what I read up so far is that SFP+ modules generally should also work in SFP ports, but does so...
- May 20, 2019
The counterpart was always a 10GBase-T resp, 1000MBase-T switch port.
AssetBurned
May 19, 2019Tutor
On the GbE side, was that an 10g or 1g module in an SFP port?
schumaku
May 20, 2019Guru - Experienced User
- AssetBurnedMay 21, 2019Tutor
Great that is what I was expecting/hoping to read.
