tantony
May 07, 2019Luminary
VLAN 1 not editable?
I have a GS724T, V5.2.0.11. I'm trying to remove VLAN 1, and it says "VLAN 1 not editable". I was able to remove VLAN 1 from proSAFE XS716T and XS728T.
Any idea why?
- May 08, 2019
tantony wrote:
Correct. This switch does not show up in the SCC. The ProSAFE switches does.
ProSafe is or was just a marketing name for the Smart Managed Pro switch line - based on earlier posts these are XS7xxT, OK.
Sorry, correction. I have a GS724TPv2, and that one shows up in the SCC. This switch is less than one month old.
That GS724TPv2 is the new one you talked of, and theere is still a GS724T with a v5.2.0.11 firmware which can't be discovered by SCC? If yes, this switch requires an update. Still, best guess is that this was some factory firmware, I can't even find the .11 in the GS724T v3 (that's a hardware version - product designation sometjing like GS724T-300NAS) downloads.
GS716Tv2 & GS724Tv3 Firmware Version 5.0.2.14 dates from summer 2012... see https://www.netgear.com/support/product/GS724Tv3#download -> previous versions
tantony
Sorry not sure if I understand. Is it because it’s EOL? I have a new gs724 but it’s v4.
tantony
May 08, 2019Luminary
Is that the reason why its not showing up on the SmartControlCenter and the ProSAFE switches do? All 3 switches are on the same subnet / VLAN.
- schumakuMay 08, 2019Guru - Experienced User
Forget the marekting names - the GS724T (v3?) does not show up?
This reads like a GS724T v3 model (v1 and v2 use much lover firmware series) - requiring an update https://www.netgear.com/support/product/GS724Tv3#download
- tantonyMay 08, 2019Luminary
