tantony's avatar
tantony
Luminary
May 07, 2019
VLAN 1 not editable?
I have a GS724T, V5.2.0.11.  I'm trying to remove VLAN 1, and it says "VLAN  1 not editable".  I was able to remove VLAN 1 from proSAFE XS716T and XS728T.   Any idea why?
  • schumaku's avatar
    schumaku
    May 08, 2019
    tantony wrote:
    Correct.  This switch does not show up in the SCC.  The ProSAFE switches does.
    ProSafe is or was just a marketing name for the Smart Managed Pro switch line - based on earlier posts these are XS7xxT, OK.
    Sorry, correction.  I have a GS724TPv2, and that one shows up in the SCC.  This switch is less than one month old.
    That GS724TPv2 is the new one you talked of, and theere is still a GS724T with a v5.2.0.11 firmware which can't be discovered by SCC? If yes, this switch requires an update. Still, best guess is that this was some factory firmware, I can't even find the .11 in the GS724T v3 (that's a hardware version - product designation sometjing like GS724T-300NAS) downloads.
    GS716Tv2 & GS724Tv3 Firmware Version 5.0.2.14 dates from summer 2012... see https://www.netgear.com/support/product/GS724Tv3#download -> previous versions
ProSupport for Business
