chosegu
Apr 12, 2017Aspirant
VLAN between FVS336Gv3 and GS724TV4
I am new to VLANs, bought 2 NETGEAR ProSafe Gigabit Dual WAN SSL VPN Firewall FVS336Gv3 and 1 GS724Tv4 – ProSAFE 24-port Gigabit Smart Switch, idea is to break the network into multiple VLANs, eac...
- Apr 14, 2017
I think I found the cause. Whenever I connect GS724TV4 with a DLink Layer2 switch things get hanged. If I disconnect it comes back to normal, maybe some sort of firmware bug.
I am closing this topic now.
chosegu
Apr 13, 2017Aspirant
No luck so far, please refer to the screenshots below:
Carl_z
Apr 14, 2017NETGEAR Expert
Hi chosegu,
As you saied ,a laptop on port 4 can get a ip address.
FW port 4 default vlan is "default" (vlan 1).
So, I think your dhcp server work in vlan 1 . it it right ?
But switch port 18 is tagged in vlan 20 , that means all traffic from switch would go into vlan 20. So client can't get ip address, since the server work in vlan 1.
Sugggestions:
1.Change switch port 18 to untag.
2.Change FW port 3 default vlan to Default (vlan 1)
Best Regards
Carl
- choseguApr 14, 2017Aspirant
