RichFlickinger
Mar 30, 2023Aspirant
VLAN Config Can't get out to internet
Hi Folks, I am a VLAN newbie so i am sorry if i'm not explaining this right or have the terms wrong. Anyway, I'm trying to setup this switch with a VLAN that can get out to the internet. The inter...
Retired_Member
Mar 30, 2023What about the Routing Mode under Routing>IP>IP Configuration? Is it enabled?
- RichFlickingerMar 30, 2023Aspirant
Yes, it is.
- Retired_MemberMar 30, 2023
Are you able to ping 192.168.1.254 and 192.168.1.1?
Yes, I am able to ping both.
more Info…I thought it might be a firewall issue. I noticed my wireless connection is set as private and the Ethernet connection is set to public. So I changed the Ethernet connection to private and I was still not able to get on the internet.
