RichFlickinger
Mar 30, 2023Aspirant
VLAN Config Can't get out to internet
Hi Folks, I am a VLAN newbie so i am sorry if i'm not explaining this right or have the terms wrong. Anyway, I'm trying to setup this switch with a VLAN that can get out to the internet. The inter...
Retired_Member
Mar 30, 2023What about the Routing Mode under Routing>IP>IP Configuration? Is it enabled?
RichFlickinger
Yes, it is.
- Retired_MemberMar 30, 2023
Are you able to ping 192.168.1.254 and 192.168.1.1?
- RichFlickingerMar 30, 2023Aspirant
Yes, I am able to ping both.
more Info…I thought it might be a firewall issue. I noticed my wireless connection is set as private and the Ethernet connection is set to public. So I changed the Ethernet connection to private and I was still not able to get on the internet.
If you can ping 192.168.1.1, you should be able to ping 8.8.8.8. If not, there is probably some issue with the default route on the switch.
