bemerson
Aug 13, 2023Tutor
VLAN Config with 2 switches and psfense
I'm trying to setup a VLAN for the first time and I'm having trouble getting it to work. Relevant screenshots below. When I connect my laptop to port 4 on the GS105 I do not get any network conne...
schumaku
Aug 13, 2023Guru - Experienced User
Hello bemerson
Is it intended on the GS308E Port 1 is configured as Tagged (for a trunk), while it's connected to the LAN on the security appliance, which does not look like a port acting as a trunk?
- bemersonAug 13, 2023Tutor
I'm not clear. On the pfsense box I have WAN connected to my modem, and LAN connected to the GS308 on port 1. I believe this needs to be a trunk?
Toggling this port to exclude does not resolve the problem. I do not discover any network when connected to port 4 on the GS105
- schumakuAug 13, 2023Guru - Experienced User
Strongly doubt. Can't see any indication the LAN security zone or this port is a trunk (tagged). Thus, tagging LAN does not make much sense to me.
Why exclude? You don't need the LAN zone on your switch? In my simple view, this port should be an access port, untagged, with the PVID set accordingly for the desired VLAN.
Guessing is a bad advise. Avoid trial and error. Make clear design on a sheet of paper. All security zones, VLANs, links
I have a clear design. It just isn't working.
All I'm trying to do is setup 1 VLAN on a single port. I cannot get the device connected to that port to recognize a network when plugged into it. VLAN 70 is not working.
As you suggested, I have tried changing the GS308 Port 1 on VLAN ID 1 to U, as well as E and I have not had any success. Something else seems to be the issue.
