GaACETech
Dec 16, 2020Guide
Basic Config - Layer 3 Switch
I have two of the GS716v2 that I need to install in a temporary work area for employee's. About 10 people per switch plus a SonicWall SonicWave AP (only 3 users will use Wifi). These switches connect via fiber (work fine). Its a single flat network.
Besides adding a static IP to the device (if thats even necessary), what are the other basic setup points that need to be done? Is this switch "ready out of the box". I had these switches available but a unmanaged switch would have sufficed also.
Also I'll mention I can't see the SonicWave device on the SonicWall. But i think thats another issue.
Thanks.
Darryl
All these switches come out of the box with a flat L2 network config. bandwidth requirements permitting one fiber link per switch is sufficient - there you go.
I would ensure the switches are managed resp. secured. Take control, change the default password, configure a static IP or set-up a MAC-IP reservation on the DHCP server so the switches can be reached and monitored at least, configure SNMP security or disable it.
You mentioned disabling SNMP. To do thta change the status of the public and private entries to 'disable'?
Thanks,
Darryl
The idea was to put up secure comunity strings and not use the default public ones. Sorry for the poor wording.
