Chrispybacon
Jul 25, 2021Tutor
VLAN Configuration
Good morning, I have a GS308T that I am trying to configure and I am having difficulty. I need one physical port (port 1) to connect to my router as the trunk / access port for all traffic to the I...
- Jul 29, 2021
tmittelstaedt wrote:
I think it's more the marketing people telling the engineers what to stick in there.
The PVID config option might exist just so they can say it exists, not because they intend it to be used.
Considering the presence (and requirement) to not forget to configure the PVID to send the untgged ingress to the correct VLAN is probably the #1 VLAN switch support issue .... figure.
schumaku
Jul 25, 2021Guru - Experienced User
Chrispybacon wrote:
I need one physical port (port 1) to connect to my router as the trunk / access port for all traffic to the Internet. I also need three VLANS configured s follows: ports 2 thru 6 as VLAN 10, port 7 as VLAN 20, and port 8 as VLAN 30. ... All VLANs need access to port 1 for internet access.
This hasn't much to do with a true 802.1q VLANs where each VLAN makes up it's own network. What you try to achieve here is a so-called asymmetric VLAN config. Netgear does not have this documented (to my knowledge).
Chrispybacon wrote:
For security purposes I want VLAN 20 isolated from the other ports, and port 30 also isolated from all other VLANs.
Just to clarify: This is exactly what an asymmetric VLAN config will not achieve. It's some tricking with the source MAC sending it over different VLANs on the switch internally, but merging together at another port.
schumaku
....probably something Netgear should bring up in a similar way.
