Chrispybacon
Jul 25, 2021Tutor
VLAN Configuration
Good morning, I have a GS308T that I am trying to configure and I am having difficulty. I need one physical port (port 1) to connect to my router as the trunk / access port for all traffic to the I...
- Jul 29, 2021
tmittelstaedt wrote:
I think it's more the marketing people telling the engineers what to stick in there.
The PVID config option might exist just so they can say it exists, not because they intend it to be used.
Considering the presence (and requirement) to not forget to configure the PVID to send the untgged ingress to the correct VLAN is probably the #1 VLAN switch support issue .... figure.
tmittelstaedt
Jul 29, 2021Star
Somewhere on the Netgear site (it may be gone, now) I recall years ago reading "layer 3 routing" in a marketing glossy for the ProSafe+ switch series. Of course I dug into it since nobody at the time was making and selling routing switches for under $2000. Well the glossies from Marketing were trumpeting that but the actual user manual for every switch I looked at from the boring engineer types said no such thing.
Another one that irks me is "layer 2 monitoring" claims for switches that have no possible way to display the mac address database inside the switch.
Unfortuately Netgear isn't the only company that engages in this. I learned a long long time ago before plunking down any cash to throughly read the user manual and see if the device can actually do what I want it to do instead of what the manufacturer wants me to think it can do. :-)
schumaku
Jul 29, 2021Guru - Experienced User
