hugo_jove
Jun 07, 2017Aspirant
Vlan isn't working correctly
Hi, I've set up switch GS724T like this : g1-g8 (vlan10) g9-g18 (vlan20) g19-g23 (vlan30) g24 MIRROR My problem is when I connect my computer on port g2 I received packet from dhcp on vlan 1...
- Jun 07, 2017
Hi hugo_jove,
Welcome to our community!
About your settings and configuration seems that you haven't change the PVID yet on the ports so the incoming traffic is still going to VLAN 1 and that will explain why you see the broadcast on the wireshark.
Could you test the following configuration :
g1-g8 (vlan10) -- Change PVID to 10
g9-g18 (vlan20) --- Change PVID to 20
g19-g23 (vlan30) --- Change PVID to 30
Let us know if it works for you!
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Jun 07, 2017NETGEAR Employee Retired
Hi hugo_jove,
Xavier Lleixa
NETGEAR CBU PLM
hugo_jove
Jun 09, 2017Aspirant
Thanks a lot !
