GaACETech
Dec 18, 2020Guide
VLAN Membership
I'm creating a VLAN with ports 14-16. The VLAN is VLAN10 and tagged.
Do I need to remove these ports from the default VLAN1 as untagged ports?
Thanks,
Darryl
1 Reply
As always, it depends what you intend to do on these three ports.
if the plan is a dedicated network with three ports where you can connect e.g. a computer, a printer it's more likely you want this network accessible untagged, so PVID 10, VLAN 10 [U]ntaged, and [-] for VLAN 1 of course.
If the plan is to connect another VLAN aware switch to extend the VLAN1 and the VLAN10 to, or a computer where the host is on VLAN 1 and some VMs on a dedicated VLAN 10 ... you keept the VLAN 1/PVID1 in place.
