cameron-minto
Nov 15, 2017Aspirant
VLAN on XS728T
Hi all I'm trying to setup what seemingly is a simple vlan on a XS728T however it is my first attempt. Im using the default VLAN 1 as one segregated network which runs several computers that have...
- Nov 16, 2017
As I understand you need two VLANs.
- VLAN 1 separated and no need for Internet access.
- Another VLAN (I will call it VLAN 10) for other devices that need Internet access.In this case, do as follows:
1. On the port that connects to your router, you Untag (U) for VLAN 10 and set a PVID of 10 on that port.
2. On the ports 17-24 you Untag (U) for VLAN 10 and set a PVID of 10 on those ports.That should be it.
Cheers!
Hopchen
Nov 16, 2017Prodigy
That should be it.
Cheers!
- cameron-mintoNov 16, 2017AspirantThat has worked an absolute treat! Thank you so much!
- HopchenNov 17, 2017Prodigy
No problem at all. Happy to help :)
Please consider marking this thread as resolved. Cheers!
- JohnC_VNov 17, 2017NETGEAR Employee Retired
Hi cameron-minto,
Welcome to our community!
Credits to Hopchen! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
