tantony
Nov 01, 2018Luminary
VLAN routing on XS728T not possible?
I'm trying to do VLAN routing on a ProSAFE XS728T. When I go into Routing, VLAN, VLAN Routing, and add VLAN and IP address, I loose connection, and becomes unresponsieve. All the ports on this switch is still on VLAN 1.
I tried the same thing on a ProSAFE XS716T, and it works.
I had Netgear tech remote in and look, and he was getting the same results.
https://kb.netgear.com/24755/How-do-I-configure-VLAN-Routing-on-a-smart-switch
According to this article, XS728T should be able to do VLAN routing.
The switch is still on the factory default 192.168.0.239. The firmware is up to date.
I tried to do this on another 728T with same results.
Figured out the solution. Not sure why this matters, but after changing the default 192.168.0.239 to static, I was able to add VLAN routing.
1 Reply
- tantonyLuminary
