cameron-minto
Nov 15, 2017Aspirant
VLAN on XS728T
Hi all I'm trying to setup what seemingly is a simple vlan on a XS728T however it is my first attempt. Im using the default VLAN 1 as one segregated network which runs several computers that have...
- Nov 16, 2017
As I understand you need two VLANs.
- VLAN 1 separated and no need for Internet access.
- Another VLAN (I will call it VLAN 10) for other devices that need Internet access.In this case, do as follows:
1. On the port that connects to your router, you Untag (U) for VLAN 10 and set a PVID of 10 on that port.
2. On the ports 17-24 you Untag (U) for VLAN 10 and set a PVID of 10 on those ports.That should be it.
Cheers!
cameron-minto
Nov 16, 2017Aspirant
That has worked an absolute treat! Thank you so much!
Hopchen
Nov 17, 2017Prodigy
No problem at all. Happy to help :)
Please consider marking this thread as resolved. Cheers!
