CrimpOn
Mar 27, 2025Guru - Experienced User
VLAN Puzzle
I would appreciate assistance diagnosing a VLAN problem. Now that many homes have Ethernet cables installed from most rooms to a central patch panel, some users find that the patch panel is not a gre...
Apr 30, 2025Guru - Experienced User
What is the IP address seen on the 50 series system for GN device?
A few...
I also looked at my GS728TX and found it was configured for 4091 as well.
CrimpOn
May 01, 2025Guru - Experienced User
The test device is a Samsung Galaxy S6 Lite. When connected to the Orbi system, it has an assigned IP of 192.168.1.25. It gets this IP address when connected to the primary WiFi and when connected to the Guest WiFi.
The original Orbi does not have the IoT WiFi network.
- FURRYe38May 01, 2025Guru - Experienced User
Ok Ya, Thought so. Ya Seem to recall users posting about how GN wasn't isolated from the main WLAN back then.
Ya Old Orbi AC doesn't have seperate IoT network.
Got a wireshark log from BE system in AP mode.
Its interesting, after collecting logs, I removed the LAN Hub and re-connected everything to my GS-278TX swtich with VLAN 4091 tagged on all ports. Have a Android Pad and Apple iPhone connected at the RBS thats ethernet connected and Guest Network enabled. Both devices are streaming from youtube currently while both connected at the RBS on the Guest Network. 🤔 Hmmm.
I do have a double NAT condition with a RS600 in router mode behind a Orbi RBR870 in router mode. Not sure if that would effect anything. Its working.
- CrimpOnMay 01, 2025Guru - Experienced User
The tablet and iPhone are connected to the Guest network on the Orbi or on the RS600
RS routers wifi is disabled.
Yes GN has isolation and seperate subnet since Orbi AX.
