Wizzard370's avatar
Dec 05, 2022
Puzzling MTU settings
Have Orbi RBK353 set up.
In Orbi set up, set MTU via WAN setup to 1492 and applied. All seems to be fine.
However if I check in CMD prompt : netsh interface ipv4 show subinterfaces
I get MTU as 1500 for Ethernet and WiFi. Not sure why.
Also, in Orbi, can I set different MTU values for WiFi and Ethernet?
  • FURRYe38's avatar
    No. MTU values are not needing any adjustments on the LAN side.
  • FURRYe38's avatar
    MTU on Orbi is for the WAN side only. Check with your ISP to see what MTU value is needed if it's required by the ISP.
    • Wizzard370's avatar
      Wizzard370
      Tutor
      Thank you. So, is there a way to set the WiFi MTU in Orbi (via Command prompt say)?
      • FURRYe38's avatar
