jcarlson04
Dec 14, 2020Follower
VLAN question on ProSafe S3300
I had to reset a switch as I took over management and I didnt have the password. I have been able to replicate everything except the VLAN participation include 5. Forgive me as I am new to Netgear sw...
schumaku
Dec 14, 2020Guru - Experienced User
jcarlson04 wrote:Forgive me as I am new to Netgear switches and I have not found a way to telnet/ssh into the switch for CLI.
No problem with that. That's perfectly correct - these are Web managed switches only. I must admit - in obvious absence of any QA and continuity rules on access and configuration - that re-creating things form the config could be nifty.
If you have a valid, recent config backup [I assume from the config fragments shown] - the K.I.S.S. would be to adjust the somehow encoded admin password in the config. Factory reset switch, set a new admin password, download the config, capture the new password hash from the config, replace the password hash in the backup config (segments like "username admin password encrypted xxxxxxxxxxx privilege 15" or "username "admin" secret 8 xxxxxxxxxxx==") and upload the config again. Effort a minute or two in a downtime, plus the time required to run to the switch, plus for the boot time.
jcarlson04 wrote:I have been able to replicate everything except the VLAN participation include 5. Is there a way to add the VLAN Participation from the web?
Yes, of course 8-)
jcarlson04 wrote:auto-voip oui 00:0B:EA oui-desc "Zultys"
Figured on how to add the additional vendor to the Auto-VoIP OUI list?
jcarlson04 wrote:interface [xxxx]
vlan participation include 5
vlan tagging 5
exit
By rule of thumb: In VLAN 5, mark all the interfaces and LAG referenced as [T]agged. Try on an unused spare port if you want, download the config and compare if you are unsure.
