PsiTech
Aug 10, 2022Aspirant
VLAN routing between m4300 and GS752 switches Not routing Meraki FW DHCP
Hello. I am trying to setup Vlan routing between a M4300(v12.0.17.6) stack and a GS752(v5.2.0.26) stack. This is to eliminate the 1gbe Bottleneck between the 2 switch stacks as they were connect...
PsiTech
Aug 11, 2022Aspirant
Adding a network overview for better clarity.
- schumakuAug 11, 2022Guru - Experienced User
Very clear to me. With the two VLANs configured, you have two L2 networks on you simple set-up:
VLAN1 does get DHCP from the Windows server, while Internet access as well as intranet access is done by L3 routing on the FW.
VLAN10 does get DHCP from the FW, which does also deal with Internet access as well as intranet access is done by L3 routing on the FW.
