hacesoft
Dec 01, 2019Tutor
VLAN routing settings
I have configured routing on the switch as follows: The address of VLAN10 is 192.168.10.1 and VLAN20 is 192.168.20.1 The default route is the route to VLANU10 on the Internet router, that is ASUS...
- Dec 08, 2019
Have a nice day,
NETGEAT switch I put into the factory settings, using the option in FW. I found out the factory settings using the physical button on the switch is different than the command in the switch. I uploaded a newer FW and re-configured everything, I set up static routing in the Internet router and it started to work normally ...
kevin_hong
Dec 02, 2019Apprentice
Hi hacesoft,
Welcome to community,
First, I guess your management vlan was "vlan 10", Right?
Currently, VLAN 10 can access internet and vlan 20 can not.
The problem is beacuse the router did not arrive a route to VLAN20 192.168.20.0/24
You must configure a static route on your Router:
like this(see attachment): Destantion 192.168.20.0 netmask 255.255.255.0 next-hop 192.168.10.1
- hacesoftDec 03, 2019Tutor
Hello,
thank you very much for your advice. I'll try it out until I get to it, probably on the weekend, then I know if it helped.
Thank you for any information
Good evening,
when trying to insert a static route, my switch says:
Error! The route could not be configured.
- kevin_hongDec 03, 2019Apprentice
Hi hacesoft,
You must configure a static route on your Router. not on your switch.
Thanks
Nice morning,
i understand now.
However, it does not solve my problem. In the meantime, we are not trying to access NET to VLAN20.
I cannot communicate from VLAN20 to VLAN10. I am on VLAN20 and PING some device on VLAN10 and the device is unavailable, only what works is PING on the VLAN10 itself, where the PING command corresponds.
When I connect a PC to the VLAN10, everything works OK. Both VLAN10 and VLAN20 communication.
In my opinion, this does not cause ROUTER on NET to have STATIC ROUTE set to VLAN20. I think there is something wrong in the NETGEAR switch.
Thank you for any answer that will help solve my problem.
