hacesoft's avatar
Dec 01, 2019
VLAN routing settings
I have configured routing on the switch as follows:   The address of VLAN10 is 192.168.10.1 and VLAN20 is 192.168.20.1 The default route is the route to VLANU10 on the Internet router, that is ASUS...
  • hacesoft's avatar
    hacesoft
    Dec 08, 2019
    Have a nice day,
    NETGEAT switch I put into the factory settings, using the option in FW. I found out the factory settings using the physical button on the switch is different than the command in the switch. I uploaded a newer FW and re-configured everything, I set up static routing in the Internet router and it started to work normally ...
ProSupport for Business
