hacesoft
Dec 01, 2019Tutor
VLAN routing settings
I have configured routing on the switch as follows: The address of VLAN10 is 192.168.10.1 and VLAN20 is 192.168.20.1 The default route is the route to VLANU10 on the Internet router, that is ASUS...
- Dec 08, 2019
Have a nice day,
NETGEAT switch I put into the factory settings, using the option in FW. I found out the factory settings using the physical button on the switch is different than the command in the switch. I uploaded a newer FW and re-configured everything, I set up static routing in the Internet router and it started to work normally ...
hacesoft
Dec 03, 2019Tutor
Good evening,
when trying to insert a static route, my switch says:
Error! The route could not be configured.
kevin_hong
Dec 03, 2019Apprentice
Hi hacesoft,
You must configure a static route on your Router. not on your switch.
Thanks
- hacesoftDec 03, 2019Tutor
Nice morning,
i understand now.
However, it does not solve my problem. In the meantime, we are not trying to access NET to VLAN20.
I cannot communicate from VLAN20 to VLAN10. I am on VLAN20 and PING some device on VLAN10 and the device is unavailable, only what works is PING on the VLAN10 itself, where the PING command corresponds.
When I connect a PC to the VLAN10, everything works OK. Both VLAN10 and VLAN20 communication.
In my opinion, this does not cause ROUTER on NET to have STATIC ROUTE set to VLAN20. I think there is something wrong in the NETGEAR switch.
Thank you for any answer that will help solve my problem.
- kevin_hongDec 04, 2019Apprentice
Hi hacesoft,
Could you please provide techsupport file of the switch(GS724Tv4)?
Let's first solve the problem of VLAN10 VLAN 20 community with each other.
Thank you
Here's my network configuration and the VLAN10/20/30 can community with each other
interface vlan10
ip address 192.168.10.1/24
interface vlan20
ip address 192.168.20.1/24
interface vlan30
ip address 192.168.30.1/24
interface g1 ------------Connect PC1
switchport hybrid pvid 10
switchport hybrid allowed vlan add 10 untagged
switchport hybrid allowed vlan remove 1
interface g2 ------------Connect PC2
switchport hybrid pvid 20
switchport hybrid allowed vlan add 20 untagged
interface g3 ------------Connect PC3
switchport hybrid pvid 30
switchport hybrid allowed vlan add 30 untagged
ip unicast-routing -------Routing vlan was Enable
