hacesoft
Dec 02, 2019Tutor
VLAN routing settings
I have configured routing on the switch as follows: The address of VLAN10 is 192.168.10.1 and VLAN20 is 192.168.20.1 The default route is the route to VLANU10 on the Internet router, that is ASUS...
- Dec 08, 2019
Have a nice day,
NETGEAT switch I put into the factory settings, using the option in FW. I found out the factory settings using the physical button on the switch is different than the command in the switch. I uploaded a newer FW and re-configured everything, I set up static routing in the Internet router and it started to work normally ...
kevin_hong
Dec 04, 2019Apprentice
Hi hacesoft,
Could you please provide techsupport file of the switch(GS724Tv4)?
Let's first solve the problem of VLAN10 VLAN 20 community with each other.
Thank you
kevin_hong
Here's my network configuration and the VLAN10/20/30 can community with each other
interface vlan10
ip address 192.168.10.1/24
interface vlan20
ip address 192.168.20.1/24
interface vlan30
ip address 192.168.30.1/24
interface g1 ------------Connect PC1
switchport hybrid pvid 10
switchport hybrid allowed vlan add 10 untagged
switchport hybrid allowed vlan remove 1
interface g2 ------------Connect PC2
switchport hybrid pvid 20
switchport hybrid allowed vlan add 20 untagged
interface g3 ------------Connect PC3
switchport hybrid pvid 30
switchport hybrid allowed vlan add 30 untagged
ip unicast-routing -------Routing vlan was Enable
