hacesoft
Dec 01, 2019Tutor
VLAN routing settings
I have configured routing on the switch as follows: The address of VLAN10 is 192.168.10.1 and VLAN20 is 192.168.20.1 The default route is the route to VLANU10 on the Internet router, that is ASUS...
- Dec 08, 2019
Have a nice day,
NETGEAT switch I put into the factory settings, using the option in FW. I found out the factory settings using the physical button on the switch is different than the command in the switch. I uploaded a newer FW and re-configured everything, I set up static routing in the Internet router and it started to work normally ...
kevin_hong
Dec 04, 2019Apprentice
Hi hacesoft,
Could you please provide techsupport file of the switch(GS724Tv4)?
Let's first solve the problem of VLAN10 VLAN 20 community with each other.
Thank you
hacesoft
Dec 04, 2019Tutor
Good evening,
I sent techsupport file for switch GS724Tv4 to [email protected]
- kevin_hongDec 04, 2019Apprentice
Hi hacesoft,
Can you upload the attachment to me ?
- hacesoftDec 04, 2019Tutor
Have a nice day,
i converted the exported log into PDF and I attach it.
I just deleted the switch password from the log ...
- hacesoftDec 08, 2019Tutor
Have a nice day,
