hacesoft
Dec 02, 2019Tutor
VLAN routing settings
I have configured routing on the switch as follows: The address of VLAN10 is 192.168.10.1 and VLAN20 is 192.168.20.1 The default route is the route to VLANU10 on the Internet router, that is ASUS...
- Dec 08, 2019
Have a nice day,
NETGEAT switch I put into the factory settings, using the option in FW. I found out the factory settings using the physical button on the switch is different than the command in the switch. I uploaded a newer FW and re-configured everything, I set up static routing in the Internet router and it started to work normally ...
hacesoft
Dec 04, 2019Tutor
Good evening,
I sent techsupport file for switch GS724Tv4 to switch_support@netgear.com
kevin_hong
Dec 05, 2019Apprentice
Hi hacesoft,
Can you upload the attachment to me ?
- hacesoftDec 05, 2019Tutor
Have a nice day,
i converted the exported log into PDF and I attach it.
I just deleted the switch password from the log ...
- hacesoftDec 08, 2019Tutor
Have a nice day,
