GaACETech
Dec 27, 2020Guide
VLAN Setup with SonicWall Wifi
Equipment 1 - Sonicwall Router 2 - Sonicwall AP 2 - Netgear GS716Tvw 2 - buildings (Building 1 is main, Building 2) connected via fiber I'm trying to Building 1 - Netgear switch, Sonicwall ...
schumaku
Dec 27, 2020Guru - Experienced User
Typical issue unrelated to the Netgear switch - corporate should provide documentation what and how the Sonic equipment is configured, from this one could at least derive on how a multi-building location should be configured.
You just have to configure what is required - if the normal corporate LAN is a flat/untagged VLAN, and the guest network is VLAN 10 and coming out somehow from the switch (like the same port like the corporate LAN but tagged, or on a dedicated port and untagged).
And then one guess in the other buildings is more than just an AP ... so there again, the switch(es) need to be configured accordingly, too.
Over the fiber connections, one does run trunk, certainly with the VLAN 10 tagged. And for the AP one can guess the corporate (and management subnet) might be flat an untagged, or tagged. Most likely, the guest SSID is mapped to a tagged VLAN on the AP.
