MikeDC
May 10, 2024Aspirant
VLan working but .... why?
I have setup a VLAN with my GS728TP as per the diagram below and it is working OK. It's fairly simple, packets on g1 ingress tagged with VLAN 11 and egress untagged on g4. Untagged packets ingressing...
MikeDC
May 11, 2024Aspirant
Thanks for the reply. The point I'm trying to make is that the packets ingressing into g4 get tagged with vlan 11 whether I have PVID set to 11 or 1. It seems that setting U on that port for VLAN 11 causes the incoming packets to be tagged, and setting PVID appears to do nothing.
schumaku
May 12, 2024Guru - Experienced User
The tagging is applied on the egress, not on ingress port. As I wrote before, the PVID definition does make the switch to put untagged ingress frames to the VLAN designated by the PVID. So the PVID config does not nothing, and untagged ingress frames can be sent to one VLAN lane only.
- Feb 22, 2022Retired_Member
