robfantini
May 29, 2018Aspirant
voice VLAN and Auto-VoIP question
we have IP phones on multiple vlans. and of course we want that traffic prioritized.
I assume that to do so I just should set up AutoVoIP on all LAGS and interfaces.
And it looks ...
- Jun 07, 2018
Apologize for the late response. As per the higher tier of NETGEAR Support, while Auto VoIP alone will provide the segregation and the prioritization, it is best practice to apply the Voice VLAN setting also to tell the phone which VLAN to tag itself to, this could be important when there is a phone connected to a switch port and there is a PC connected into the phone.
DaneA
NETGEAR Community Team
DaneA
Jun 05, 2018NETGEAR Employee Retired
Not sure if this will help. However, let me share you the old article below and see if you will get an idea.
Configuring voice VLAN feature on the NETGEAR Smart switches
DaneA
robfantini
Jun 06, 2018Aspirant
can i ask this:
does auto-voip require a voice vlan to be set up?
