Kaizenba's avatar
Kaizenba
Follower
May 04, 2021
VoiP on Netgear GS728TP Problems
Hi There we are having basicly the same problem as this thread,
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/VOIP-Issues-on-Netgear-FS728TP-switches/td-p/1293102
Phones randomly logging out and needing to be restarted.
Dropping calls mid-conversation (internal and external).
The difference is that we have no VLANs at all, the voice network does not touch the data network. All the switches are a variation of the 728, what is odd is that none of the phones show up in the ARP table of any of the switches. Does anyone have any advice?
O and we are using a cloud based PBX not onsite.
Thank you in advanced.
1 Reply
  • schumaku's avatar
    schumaku
    There are many different switch models and generations (dating from roughly two decades) carrying the number 728. Exact model and firmware version required.
    ARP is an IP-MAC thing, so related to routing - look for the Address Table, aka. MAC Address Table.
    No connection to the data network, and no VLAN - so this is a dedicated VoIP switch. Checked the Auto VoIP feature does not interfere with your network usage for example? Any indications in the switch logs?
ProSupport for Business
