Gearo
Oct 24, 2022Follower
VPN access GS108PEv3
Hi!
with all newer versions than GS108PEv3_V2.06.10GR, VPN access to the switch isn't possibble.
GS108PEv3_V2.06.10GR is the only firmware that works with vpn.
Does anybody know why?
1 Reply
Scratch the idea it's about VPN - the switch does not know anything about.
i suspect it's a imitation (or potentially a bug) on that simple IP stack on the embedded controller. It appears it does not honor the default gateway configured. Same eg. on the GS105PE.
