MikaelN
Oct 13, 2015Tutor
Web firmware upgrade for GS108Ev3 failing
I wante to upgrade to version 2.00.05 but don't have a Windows machine handy. So I thought I'd use the web interface. After entering "loader mode" on the switch, I uploaded the firmware, only to ...
- Oct 13, 2015
And an update: Managed to borrow a Windows machine. The ProSafe utility (latest version) did not even find the switch. Nice!
Then I tried the firmware upgrade from chrome on the windows machine, and voila, that actually worked! What on earth could be the issue?
So to summarize: firmware upgrade from chrome or firefox on linux failed, Prosafe utility failed to detect switch, Chrome on Windows saved the day.
I'm leaving more confused than I was when entering.
hazeii
Jul 27, 2017Aspirant
This issue got me today, so it's still happening. Basically it appears that the Netgear firmware file upload only works on certain browser/OS combinations; however once in 'firmware upload mode' there's no way out without uploading firmware (a factory reset *does not* restore the device to default operation).
It can get particularly complicated to sort out if the switch gets an address via DHCP on a different network to the default (e.g. 192.168.1.x), since a reboot in firmware loader mode appears to result in it defaulting back to 192.168.0.239 and *not using DHCP* - giving the appearance of the firmware update having 'bricked' the device.
As others have noted, the fix is to use a Windows box with Chrome, and configuring networking as necessary to access the switch using 192.168.0.239.
eugirdor
Aug 06, 2017Aspirant
First, thanks to those who were troubleshooting this before as it helped resolve my issue
Note: For systems with multiple interfaces or if you have renamed the interface
* Run this from a command prompt with administrator access
netsh interface ipv4 show addresses
* Find the interface with the appropriate network range for your switch (copy the portion after "Configuration for interface")
* Run this command with the name of the interface
netsh interface ipv4 add neighbors "<insert network interface name here>" "<insert switch mac address here>"
Example: netsh interface ipv4 add neighbors "LAN1" "192.168.2.40" "a0-63-91-bb-bb-bb"
