830se
Jul 12, 2021Aspirant
What are the exact dimensions of the barrel plug on the power adapter for GS110TP smart switch?
I'm looking for exact dimensions of the barrel on the power plug for a NETGEAR GS110TP smart switch i.e. inner and outer diameter in millimetres.
schumaku
Jul 12, 2021Guru - Experienced User
2.1 mm and 5.5 mm most likely - compare to your GS110TP unit if this makes sense.
