830se
Jul 12, 2021Aspirant
What are the exact dimensions of the barrel plug on the power adapter for GS110TP smart switch?
I'm looking for exact dimensions of the barrel on the power plug for a NETGEAR GS110TP smart switch i.e. inner and outer diameter in millimetres.
830se
Jul 13, 2021Aspirant
Thanks for the reply.
Unfortunately the dimensions are not 2.5x5.5mm. Using a ruler I can see the outside diameter is roughly at least 6mm and the inside diameter is at least 3mm. I'm really looking for the exact measurements.
schumaku
Jul 14, 2021Guru - Experienced User
No other choice than measuring the inner pin with the right tool and compare with the available connectors - probably 3.1 mm inner, 6.3 mm outer.
- 830seJul 14, 2021AspirantI don't own the right tool. This is the NETGEAR website. Can't they tell me?
- schumakuJul 14, 2021Guru - Experienced User
I'm not Netgear, and have no similar switch at hand. Netgear might be able to provide the formal order number for a replacement power supply order from the distribution channel, or you can order one on the Netgear support channel.
It makes sense to use a thicker inner pin to avoid accidential connection errors. The (obviuous wrong) number I have provided here before came from a second source power supply vendor.
Can DaneA please assist here?
- 830seJul 14, 2021AspirantI understand, I'm not asking you to tell me the exact correct dimensions. I'm asking NETGEAR to tell me because their support webpages suggested I ask this question here in this forum.
I'm do not need a replacement power supply. Just the exact correct dimensions.
