UPP_Ronnie
Jun 02, 2021Tutor
What is the most efficient way of keeping several remote smart switches up to date
Hi all, we have a few Netgear smart switches dotted around various remote sites. I was wondering if there is a way to centrally view what firmware versions they are all on and if there are any firmwa...
JohnC_V
Jun 02, 2021NETGEAR Employee Retired
Welcome to our community! :)
That would really depend on the switch that you have. If the switch does not support Insight App, then you may use the Smart Control Center in order to detect all the switches on the network and identify the firmware version. But if it does support Insight, then you can just see it from there.
John
NETGEAR Community Team
UPP_Ronnie
Jun 03, 2021Tutor
Hi John,
Just checked at least 3 and they all do have Insight feature although not set up. Looking at the setup process it does say it wipes the device back to factory default. that makes it something that needs to be planned out of hours.
The Smart Control Center is that meant to be installed on a machine in the local network? we have about 20 or so remote sites, not all has Netgear switches installed. But i guess i cannot install Smart Control Center on a server in the DC and hope to scan a remote network for Netgear switches?
- schumakuJun 03, 2021Guru - Experienced User
Don't think so. SCC can discover and act on the local network only.
