PaulaP's avatar
PaulaP
PC keeps switching from ethernet connection to wifi
I have a Netgear AC1750, model R6400.
I have my home desktop PC hooked up by ethernet cable.  For some reason, the router doesn't always recognized that it should connect through ethernet cable and prompts me to select a wifi instead.  Do you know why this is and how I can get it to always connect through my ethernet cable. We have several laptops that use the wifi but my PC needs to be through ethernet.  I don't know a lot about this so I'm hoping someone can help please.  Maybe it's a set up thing?
Thanks,
  • Hi PaulaP,
    You can try temporarily disabling the wireless adapter on the computer so that the only active connection is the one for Ethernet. You can go to the Control Panel > Network and Sharing Center > Change Adapter Settings > Right click on the wireless adapter > Disable.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi PaulaP,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi PaulaP,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
    • PaulaP's avatar
      PaulaP
      yes, that solution worked.  For some reason I had WiFi enabled on my desktop.  Thank you for following up.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi PaulaP,
        You are welcome. Glad to know you got it working.
        Dexter
        Community Team
