SBW
Jan 12, 2017Aspirant
When connecting a new computer to the router no connection
I have tried to connect a new computer to this router and it is failing to connect, History - This mahine has never worked on this LAN - I re-built this machine outside of this network and the ...
- Jan 13, 2017
Hi SBW,
The GS116v1 is an unmanaged switch, this is only a pass through plug-and-play unit. This switch does not have any configuration and software, there is no way to tell it to block its ports. Here are some things that you can check:
- Make sure that the router (where the switch is plugged in) is passing traffic along with its capability to give out IP addresses to its clients.
- Check the LEDs on where the devices are connected, see Troubleshooting in the installation guide.
- Try using different power outlets (or power adapter if one is available). If the power adapter is going bad, there is a chance that it might not supply the correct amount of power causing the switch to not work properly.
Let me know if these will help.
Thanks,
JohnRo
Jan 13, 2017NETGEAR Employee Retired
Hello SBW,
Welcome to the community!
I would lime to know the model number of the device that you are working on.
Thanks,
- SBWJan 13, 2017Aspirant
Hello John,
The model number is
NetGear 16 Port Gigabit Switch GS116 v1
Kind regards
Simon BW
- JohnRoJan 13, 2017NETGEAR Employee Retired
Hi SBW,
Thanks,
- JohnRoJan 16, 2017NETGEAR Employee Retired
Hi SBW,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
