DaDirk
Dec 04, 2015Aspirant
Where can dowload smart wizard configure for OSX (El Capitan)
Can you tell me where can download smart wizard configure for Macintosh OSX?
- Dec 04, 2015
Hello DaDirk,
Welcome to the community!
I apologize but currently there is no Smart Wizard, Smart Control Center and Prosafe Plus utilities available that will work with Mac systems.
Alternatively, you can configure the switch via GUI using its default LAN IP address on a web browser.
JennC
Dec 04, 2015NETGEAR Employee Retired
Hello DaDirk,
DaDirk
Dec 06, 2015Aspirant
Hello JennC,
many thanks for your fast answer. It works really good and get IP-Adresse when enable/build DHCP-Server. :smileyhappy:
Dirk
