PeterWgtnNZ's avatar
PeterWgtnNZ
ReadyNAS and El Capitan - Problems!
Hello,
I am running El Capitan (OSX 10.11) on my Mac laptop.
I have 3 shares on my ReadyNAS Duo V2, using the latest version of RAIDar (6.1) I can see the device (which is plugged into the router on my network) & it shows I have the latest firmware (5.3.11).
The admin page is accessible - and confirms when I check for updates that the firmware is current (i.e. no updates to apply).
I have setup both AFP and SMB protocols on all shares.
From my Mac I can manually mount & access SMB shares, but am getting nothing in the finder for AFP but am seeing PT-NAS (CIFS) which I assume is for SMB access (but this doesn't allow me to connect either).
It looks as though the latest OS version is broken for access to the NAS - help!
Thanks,
Peter Thompson
  • I just checked and I can connect to my Duo v2 via AFP without any issue. I am running 10.11.2 at the moment.
    This sounds like a discovery issue. You might want to try globally turning off the AFP service then starting it again.
    In the Finder if you go to Go > Connect to Server, can you connect to afp://192.168.1.50 ?
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi PeterWgtnNZ,
    Welcome to the community!
    Try to disable and enable the AFP protocol on those shares and once enabled, ensure Everyone is set to R/W and the Allow Anonymous Access checkbox is ticked. Resetting the permission of the said share is also a procedure you can try if the above suggestion didn't work.
    Device Software Manual - check pages 33-35
    Hope this helps!
    Kind regards,
    BrianL
    NETGEAR Community Team
    • mdgm-ntgr's avatar
      mdgm-ntgr
ProSupport for Business
