iPadawan
Nov 26, 2021Follower
Will ethernet cable CAT6a, CAT7 with metal shield fit in the GS724Tv4?
Dear all, The title says it hopfully all. Will fit the metal shielded RJ connectoren in coporation with CAT6a and CAT7 cables in the the router? Thank you. R
schumaku
Nov 30, 2021Guru - Experienced User
Shielded and non-shielded RJ45 connectors have the same outer dimensions.
