Caprichoso
Apr 12, 2021Tutor
XS708T has different iperf transfer rates to/from iMac Pro - QNAP NAS
I have a Netgear XS708T 10 Gb switch which connects my QNAP and iMac Pro 11.2.3 10 Gb ports. The results of an iPerf3 test are different, depending upon the direction: QNAP to iMacPro [ 5] 0....
Caprichoso
Apr 13, 2021Tutor
Disable flow control all over.
Set to full duplex (no flow control) on the iMac. Flow control is disabled on switch port. Dunno if can be done on QNAP.
Is iperf3 operated on the native QTS (NAS model and version please) or on a VM, or on a container?
Yes, on native QTS TVS-872XT QTS 4.5.2.1630
[~] # which iperf3
/usr/bin/iperf3
It this on a native QTS network port, or on a Virtual Switch port?
Virtual Switch port
What about the "real" SMB protocol file access performance in comparison
Blackmagic gives me 284.4 MB/s write, 745.9 read to the QNAP.
Caprichoso
Apr 27, 2021Tutor
QNAP support had me do a direct connect to the iMac bypassing the switch. The speed problem was still there, so probably not a netgear issue. Ticket has been assigned to QNAP development.
