Afzalb
Nov 19, 2024Aspirant
XS712t (v1) support of IEEE 1905.1
I'm currently looking at the latest generation mesh wifi systems, but would prefer a wired backhaul. On sites for the TP-LINK BE85, for instance, people are reporting issues due to network loopin...
Afzalb
Nov 20, 2024Aspirant
Thank you everyone for your very useful comments and tips.
In the end, I'm going to go with WiFi 6/7 APs, using 2.5Gbps PoE. As the XS712t can't do 2.5, nor has it got PoE, I will buy a cheap unmanaged switch that can do that, and has an SFP+ 10GBase-T module to connect to the XS712t.
