ger24's avatar
ger24
Tutor
Aug 27, 2020
XS716T ports and spec limitations
just read the data sheet: https://www.netgear.com/images/datasheet/switches/SmartSwitches/XS708T_XS712Tv2_XS716T_XS728T_XS748T_DS.pdf In order to aviod making mistakes on configuring XS716T,  I woul...
  • schumaku's avatar
    schumaku
    Aug 31, 2020
    ger24 wrote:
    I found that when using port 15T/16T(RJ45) the port 15F/16F(SFP) cannot be used. port T and port F can't be operated simultaneously.
    On switch port 15 you can use either 15T or 15F, on 16 you can use either 16T or 16F
    ger24 wrote:
    which means there are totally 16 ports on XS716T can be used simultaneously, is it?
    Yes, 16 switch ports - as the product name shows.
ProSupport for Business
