Oh_Drother
Jan 07, 2021Aspirant
XS728T - Disable HTTP Access?
Hi all, I attempted to look through both previous posts, as well as the manual, but with no luck I was hoping someone could let me know whether or not it is possible to completely disable HTT...
Oh_Drother
Jan 11, 2021Aspirant
schumaku Understood. Am I correct in assuming that I could create an ACL denying http in/out in order to achive this?
schumaku
Jan 11, 2021Guru - Experienced User
Di you have an security audit rewiring the restriction or us this just a nice to have? I would be careful banging this door completely.
- Oh_DrotherJan 11, 2021Aspirant
schumakuThis switch is a temporary solution, and our security audit team will be banging down the door to make sure HTTP is not accessible for this switch. While we do completely understand the risks of disabling HTTP, if we cannot simply turn off HTTP, then we will set up an ACL to disable HTTP access unless you are telling me that isn't a possibility.
- schumakuJan 11, 2021Guru - Experienced User
The risk does not really exist if the policy is using https - easy mitigation. 8-)
if its a temporary thing, they will survive and allow an exception anyway.
