creamelectricar
Jul 02, 2019Tutor
XS728T 10Gbe connection issues
Hi all, We're having some very frustrating issues with our XS728T 10G switch. Mainly that it has trouble negotiating 10G connections over longer cable lengths. I've done a lot of tests and I've n...
- Jul 10, 2019
Just to follow up on this. We were finally able to get through on the chat function, Netgear issued an RMA, we received the new switch today and it works as expected. The problem was a fault with the switch.
schumaku
Jul 04, 2019Guru - Experienced User
creamelectricar wrote:Our XS716T works as expected, just not the XS728T.
Was the XS728T replaced already?
creamelectricar wrote:As for chat support, thanks I'm aware, have all our gear registered, but the chat function does not work. We get an error every time that says we have been blocked due to too many connection attempts from our end. So the only avenue of contact we have does not work - no email support as an alternative so I can't report the issue with the chat.
Well, that's very different from what you reported before. ChristineT this is something to investigate.
Is your Internet connection behind some CGN (Carrier Grade NAT) probably? Use a mobile phone over 3G/4G/LTE/5G whatever instead.
creamelectricar
Jul 10, 2019Tutor
