menwithven's avatar
menwithven
XS728T add 100Mbit support via SFP?
We have a XS728T switch and have a device that is 100Mbit/s (100BASE-T) and would like to know if there is any way to connect it to this switch via an SFP?   It does not seem like Netgear offers an...
  • LaurentMa's avatar
    Apr 05, 2020
    Hi, thank you for your message.
    Unfortunately no, XS728T won't support 100M at all. 10G copper ports can only do 10G or 1G, same for the 10G fiber SFP+ ports. So it is impossible to connect a 100BASE-T device to a XS728T.
    Usually SFP+ ports can't do 100M at all, only 10G or 1G speeds with corresponding SFP modules.
    Now, I can tell you that M4300 10G models (www.netgear.com/m4300) can support 100M on their copper 10GBASE-T ports. To help you, datasheets indicate the supported port speeds per interface, for instance in Hardware at a glance or in Tech Specs. Usually the datasheet is available under the Resources tab in each product page. I hope this helps,
    Regards
ProSupport for Business
