Westerkappeln's avatar
Oct 26, 2016
XS728T Can't change LAG to LACP
Hello, have a new XS728T, Firmware 6.5.1.26 Got some strange behavior while trying to configure LAG. - can't create new LAG - can't change LAG-Type to LACP on predefined LAGs getting Message "LA...
  • Carl_z's avatar
    Oct 26, 2016
    Hi Westerkappeln,
    Welcome to Netgear's online community!
    If your trouble is still there,kindly suggest you to check if the ports that in lag up or not.
    If none port is up,it is normal that unable to chage the lag-type.
    Now two suggestions for you (pick up either one)
    1.Bring port members up(at least one of the port menbers is up),then you can change the type of lag.
    2.Delete the predefined lag,then config a new lag with type of LACP.
    May the answer helps
    Carl_z
ProSupport for Business
