Westerkappeln
Oct 26, 2016Aspirant
XS728T Can't change LAG to LACP
Hello, have a new XS728T, Firmware 6.5.1.26 Got some strange behavior while trying to configure LAG. - can't create new LAG - can't change LAG-Type to LACP on predefined LAGs getting Message "LA...
- Oct 26, 2016
Hi Westerkappeln,
Welcome to Netgear's online community!
If your trouble is still there,kindly suggest you to check if the ports that in lag up or not.
If none port is up,it is normal that unable to chage the lag-type.
Now two suggestions for you (pick up either one)
1.Bring port members up(at least one of the port menbers is up),then you can change the type of lag.
2.Delete the predefined lag,then config a new lag with type of LACP.
May the answer helps
Carl_z
Carl_z
Oct 26, 2016NETGEAR Expert
Hi Westerkappeln,
Carl_z
Westerkappeln
Oct 27, 2016Aspirant
Hi Carl-z, Evans-o,
thanks a lot for your help.
added an active port to the LAG, changed LAG-Type to LACP and afterwards removed the active port.
I never could imagine, that this works, but it does :-)
I still can't neither delete predefined LAGs nor create my own, but this doesn't matter. That's a thing, I can live with.
Thanks again, and have a nice day
Ferdinand
- DaneAOct 27, 2016NETGEAR Employee Retired
On behalf of Carl-z and Evans-o, you're welcome.:) I am glad to know that it works.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
Feel free to post your future concerns here in the community.
Cheers,DaneA
NETGEAR Community Team
- Jul 03, 2017Retired_Member
